跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Microphone and earphone don`t work
Hello guys!
I have big problem with my Iphone 6. When I try to call someone I can`t hear any signal or voice. The person can`t hear me too.
I tried to record something with Voice Recorder - nothing. I tried to make a video with the camera, but there is no sound. On calls I can only hear in loudspeaker mode, but nobody hears me. I tested with bluetooth watch and I can speak, but only in bluetooth.
I am with ios10, but made hard reset and downgraded to ios9.3.5, but no result.
Do you have ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
It´s not a software porblem. Sounds like defective cirrus logic (audi ic) on the back of the logic board. It´s very hard to fix. You need to replace a bga chip.
这个答案有帮助吗?
得分 2
1条评论:
Hi Marius, stumbled on this post with similar symptoms and wondering if you could clarify. I have an iPhone 6 and noticed similar problems after dropping it once. I cannot hear or speak during calls unless I use speakerphone or bluetooth headphones. I cannot record audio from microphones using video from front or back, nor can I record audio using voice memo app. Bluetooth and wired headphones appear to work, is that consistent with damage to the cirrus logic board being damaged?
I would find it unlikely that all microphones were damaged as well as the earpiece speaker, so the only other possibility I could conceive would be damage to a flex cables.
完成的
添加一条评论
Any water damage to the phone?
I like to start simple: change the earpiece speaker, front camera flex and Lightning port. That will replace both microphones and your earpiece speaker. Your loudspeaker is working, so you don't need to replace those.
There is a good chance the phone had some minor water damage and those components were damaged since they are the ones that have openings that water can get into.
iPhone 6 Front Camera and Sensor Cable
iPhone 6 Lightning Connector and Headphone Jack
iPhone 6 前置摄像头和感应电线替换
iPhone 6 Lightning 接口组更换
iPhone 6 Lightning Connector and Headphone Jack图片
产品
$19.99
iPhone 6 Front Camera and Sensor Cable图片
产品
$19.99
iPhone 6 Lightning 接口组图片
指南
难度:
困难
1 - 2 hours
iPhone 6 前置摄像头和感应电线图片
指南
难度:
中等
30 minutes - 1 hour
这个答案有帮助吗?
得分 0
1条评论:
No water damages.
Everything started when I spoke with a friend in Facebook Messenger. It was OK 20 minutes and all at once he told me: I can`t hear you. I tried to recall but again no microphone. Then I noticed the problem with the earphone too...I bought the phone refurbished and since last week is mine.
完成的
添加一条评论
The audio jack is not working too...
这个答案有帮助吗?
得分 0
1条评论:
The audio jack is part of the same flex that holds the lower microphone. If you replace the parts Josh mentioned, that will include the audio jack.
完成的
添加一条评论
添加你的答案
Nicky 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 120
