跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
Changing logic board. Format SSD?
Hi.
I need to change my logic board (i5 4gb ram) because it is only charging with 2W. To a used one from ebay (i7 8gb ram).
The SSD is encrypted. Can I still use the same SSD without formatting it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Before you alter anything why don't you just make a clean full backup unencrypted.
If you used Apple's FileVault2 encryption you should be fine. I would still have a master password and a recovery key setup beforehand.
If you used someone else's encryption tools you'll need to ask them.
这个答案有帮助吗?
得分 2
2条评论:
I am using Apple's filevault. Is the key software/hardware stored on the SSD or on the logic board?
完成的
The key here is the alpha-numeric the software gives you as a recovery key. Just write it down. The master password is what you defined when you set it up.
Apple does not use anything within the system to lock the FileVault image to (refer to the above links for the details)
完成的
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 293
