跳转到主内容
第三代 Surface Pro 平板,发布于2014.6.20
123 个问题 查看全部
Surface Pro 3 Broken Kickstand Hinge
The left hinge of my Surface Pro 3 snapped the other day when closing the kickstand and it is completely broken free. The kickstand wont close flat now and i am worried about traveling with it. The remaining hinge seems to be doing fine for now but I believe it will break eventually.
I have seen the kickstand replacement but is there anything for replacing the hinge itself?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
Did you ever find a solution? I need one.
这个答案有帮助吗?
得分 0
添加一条评论
I never did, called around to repair shops but nobody wants to try it unless I signed a waiver releasing them from liability. They were all afraid they'd break it.
What I ended up buying though is a Keyboard from Brydge (link below). You slide the surface into the hinges on the keyboard and essentially makes it a laptop, has worked really well for me so far, though I like the kickstand and MS keyboard combo better (thinner, better looking). At least it's functional for now!
https://www.brydgekeyboards.com/products...
这个答案有帮助吗?
得分 0
3条评论:
Thank you for replying! I found a solution too in just buying a case for it that included a kickstand. Here's the link -https://urbanarmorgear.com/products/case...
It isn't the best kickstand for adjusting the angle (or sleek-looking either) in the world, but it works for me.
Once again, thanks for getting back to me, I really appreciate it!
完成的
Thank you for getting back!
I have found a solution also in just buying a case with a built in kickstand. It isn't flawless (kind of hard to adjust angles) but works good enough for me. It's brand is Urban Armor Gear just in case you were curious, and I would link it but this reply to you got deleted by a bot for insufficient text when linking, so sorry!
Anyway, thanks again for your reply, I really appreciate it!
完成的
The only way to replace the hinge itself is to get under the screen, which has a high probability of cracking when removing,. You are fortunate that your screen didn't crack when the hinge broke, as that's what happened to mine. As others have mentioned, it's best to get a case with an included kickstand.
The hinge itself can be found used on Ebay.
完成的
添加一条评论
添加你的答案
Tim Massie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 18
总计 4,929
