跳转到主内容
加入维修社区 - 创建账户
2.3L 4cyl or 3.0L V6, 6th Generation
car over heating problem
i change my car radiator but the cooling fan not turn on automatic and my car is over heating from that problem i check the fuse and rely they are good i change the cooling fan switch but the fan not start what i do .kindly give me some suggestion.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi,
What does the temperature gauge on the dash tell you about the temperature? Does it show normal or hot etc.
1.Have you checked the thermostat?
With a cold engine, remove radiator cap, start engine and allow to warm up. If thermostat opens then you will see 'flowing' of coolant in radiator neck. If the coolant doesn't seem to move, switch off the engine and feel the top and bottom radiator hoses. If the bottom hose feels colder than the top the thermostat hasn't opened. Be careful as the coolant expands when it heats up and may overflow the radiator neck.
2. If the thermostat is OK, the radiator fan is controlled by the ECU. There is an ECU coolant temperature sensor which tells the ECU to turn on the fan. Be aware that there are 2 coolant sensors close to each other. The one with only one wire is for the gauge and the other with 2 wires is for the ECU.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
farooq shah 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 5,472
