跳转到主内容
Broken screen - touch function didn't work before or after repair
Hi,
I'm repairing an iPod 3rd Gen that came to me with a broken screen. The touch aspect didn't work.
After replacing the screen/digitizer, the touch aspect still doesn't work. I've double and triple-checked the cable and am pretty sure I have it in right.
I have also tried hard resetting, restoring, multiple times.
Any help?
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I just gave up... nothing I could find. I assume the drop damaged the logic board.
完成的
添加一条评论
1个答案
已选择的解决方案
If the touch screen doesn't work, then either the digitizer is broken, or the connection is bad, or the logic board is broken.
If you've already tried replacing the digitizer, then disconnect the cable and examine the connector on the logic board with magnification, and see if you see anything you can fix. If not, then you'll have to replace the logic board.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
spacec0w 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 2,198
