跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Fixing Error 23 - Error 512
Hello !
My Iphone3G won’t restore anymore, It stops with an error 23. By opening the error report, I can read that the error is in fact error 512, communication failure.
Is there anyway to fix/rapair that ?
May be a part to be changed ?
Thx in advance for your answer.
Yak
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
This answer deals with the same issue so maybe it will help shed some light on your problem. In short, it looks like the issue has to so with either a bad port on the iphone, a bad cable or corrupt iTunes software.
这个答案有帮助吗?
得分 0
添加一条评论
hardware error like 23 has too much variables
it means radio comm and more
the best thing to do is just pull out the pcb and insert it in different iphone that is a "known good one" (instaed of the pcb there) if error persists then its a = board issue with the radio's either bb,check for all parts '
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
2012 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,292
