跳转到主内容
LG的旗舰智能手机,具有独特的滑出电池和可拆卸的I/O模块,支持多种硬件扩展选项。发布于2016年4月。
146 个问题 查看全部
Where is the wifi and Bluetooth 2.4ghz antenna
My LG G5 wifi works good at 5ghz , but at 2.4ghz the signal is poor. And the Bluetooth signal is bad too unless I put my moto360 at the screen of the phone. So I wonder maybe it lacks a wifi & Bluetooth antenna.Can you tell me where is the antenna? I can get a new one then install it。
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Hi,
Here is a link to the Ifixit guide to teardown a Lg G5.
At step 14 in the guide it shows the placement of the WiFi/BT controller chip, highlighted in a red box. As there are no obvious antenna connections nearby and the complete parts teardown doesn't show any separate antenna leads, I suspect that the antenna(s) are most probably coils mounted on the board itself. If this is correct either one of the coils is loose or the controller chip's section for 2.4GHz is faulty. BT operates on the same frequency so it would use the same antenna.
LG G5 Teardown
这个答案有帮助吗?
得分 3
添加一条评论
I have the same problem. By the way, I need the service manual. Someone has?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bibili 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 16
总计 8,130
