跳转到主内容
Repair guides and support for televisions manufactured by Sony.
748 个问题 查看全部
3 Red Flashes. Screen won't come on.
I have a Sony KDL-55W802A tv. Walked into the room the other day and the tv wouldn't turn on and the red light would repeatedly flash 3 times. I looked up the code and it said it was either a bad main logic board or the power board. I tested and replaced the power board to no avail. Can anyone please give me insight into this issue? I'm stumped!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I have a Sony KDL-50W800B 3d TV and I am still getting the 3 blinking lights even after I changed the main logic board and the LED driver board.
完成的
Mostly it is NAND error (bad chip and or corrupt file system), no communication.It is programmed.it is same as the hard drive for computer.it goes bad by time, unfortunately.
完成的
添加一条评论
6个答案
已选择的解决方案
Bad main logic board or power board,
error codes & Sony KDL-55W802A
https://www.youtube.com/watch?v=0KGysXbx...
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Hey.. its the cover that goes on where the bulb is. There is a little nub on the cover sticking out and when the cover is in place it pushes the switch in. My cover has gotten a little melted and tweaked so the nub doesn't push the switch in all the way. I took some masking tape and rolled it in a little ball just so it fits in the hole. Maybe the size of a bb . After I reinstalled the cover I turned the tv on and waaaaaalaaaa! Its working again. I then put the other cover on that covers all the buttons and stuff and called it a day. . Hope this helps u if u didnt already go buy a flat screen.
Off topic…
这个答案有帮助吗?
得分 5
4条评论:
Thank you the door was loose after changing the bulb . I closed it and tightened it and walla it works.
完成的
I can't find the switch?
完成的
What bulb? I don't have a bulb.
完成的
Thanks very much! Me and my 31 week pregnant daughter got a free T, carried it down ladies stairs, Got it home and it didn't work. Your answer saved us from putting on curb.
完成的
添加一条评论
I have a Sony projector TV and it went out I thought it was the bulb but it was the switch for the bulb door was broken so I just took the 2 wires from the switch and soldered them together and it solved the problem and I didnt have to worry about the other switch because it was still good but u wanna keep everything clean of dust around the fan and bulb u b surprised how much builds up and fast.
这个答案有帮助吗?
得分 2
添加一条评论
I have a sony 50w829b and I got no picture and the red light just keeps flashing 3 times in accordance what wrong with my tv can I get it fixed
这个答案有帮助吗?
得分 0
添加一条评论
We did not know that our bulb door was not installed properly. After reading this post we adjusted that and the TV started working fine again. Thank you.
这个答案有帮助吗?
得分 0
添加一条评论
Which bulb or cover and button you are talking this tv. I have same kind of problem this type of tv SONY KDL50-800, blinks 3times, no
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jared Stephens 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 77
过去 30 天: 419
总计 60,932
