Flash not working on iPhone 5s
I have a 5s that the flash light/camera flash did not work, so I replaced that cable and it still won't work. Any suggestions?
I'm thinking it's going to be a board level issue where there is liquid damage on the board where the ribbon cable plugs into or near / on the chip or component giving power to the flashlight when it is asked to be turned on is damaged.
With the new power button and audio cable flex do the power and volume buttons work fine?
这个答案有帮助吗?
yes, volume and power buttons work fine. Is it possible for both of those to work and the flash not to work?
Yes as each component sometimes uses a different circuit line on the ribbon cable / pinouts on ribbon cable socket.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 643
2条评论
wot cable did you replace sir
由 victor osaghaede 完成的
iphone 5s Audio control and power button cable. It's the one the flash is on.
由 Nick Chambers 完成的
