跳转到主内容
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 个问题 查看全部
Nintendo 2ds problems. Help!
So the problem with my 2ds is that if I turn it on it will not show anything and just power off two seconds later. It was working 20 min prior to this and nothing happened to it at that time. Please help! Ok new development the screens flash and you can hear a small pop from the speaker and then it just shuts off.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
This may help: dsi flashs on and then turns off
It's a different model, but being a Nintendo DS, I'm sure the issue is somewhat relatable to yours.
这个答案有帮助吗?
得分 0
2条评论:
Ok it may be the same problem but do you know where I can get a guide for my model?
完成的
It may be the same problem but do you know where I can get a guide to fix it for my model?
完成的
添加一条评论
Hi,
The little pop is telling you that the unit is in short circuit. Possible causes:
- Broken screen (only way to verify is replacing the screens)
- Short circuit fuses (F1 a/o F2) - multimeter and check for continuty
- Disconnected wifi card - Verify if not sitting properly
Good luck and good repair.
JM
这个答案有帮助吗?
得分 0
添加一条评论
Game will not download
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aries 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 330
