跳转到主内容
Why can't I sent or receive calls and texts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Maybe you accidentally put it on airplane mode. It will act this way even though wifi is connected. Here is a link that should help. Tap or click on the blue link.
http://www.virginmobile.ca/en/support/st...
这个答案有帮助吗?
得分 0
添加一条评论
Turn iMessage off and back on, or turn iMessage off to see if texts can be sent and received.
Make sure the contact is not on your block list. To do so, go to Settings > Phone > Blocked, and confirm that the user is not on any block list.
If you have an old iPhone or another iOS device that you sometimes use for iMessages, try toggling iMessages off there and sign out of your Apple account. You can sign out by going to Settings > Messages > Send & Receive and tapping on your Apple ID, then choosing Sign Out.
Delete your current conversation with the problem contact(s) and start a new one.
Delete and re-enter said contact(s).
Simultaneously hold the Sleep/Wake and Home buttons to reset your device.
Try going to Settings > General > Reset > Reset Network Settings. You will have to re-enter some passwords and set network connections up again after this.
You could try a factory reset of your iPhone.
Contact Apple Support, or take your device to an Apple Store to get it checked out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John McGilloway 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 709
