跳转到主内容
安卓智能手表维修指南。
How do I change the time on an Android smartwatch?
My wife's K88H Smartwatch seems to have all its apps working but shows an incorrect time 4hrs + behind current time. I cannot seem o pair it properly with my mobile on Bluetooth. How can I change the time on it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
11条评论
z66 smart watch the time of watch not set properly please help me
完成的
Hi. My Kingware 88 time reset to London time -2 when disconnected from phone. When connected again time sync to SA time. How can the watch be set to store SA time when not connected to phone. Thanks
完成的
Hi can anyone help me change the time on my fb4e ???
完成的
How to change ky11 smart watch timing?
完成的
I need hlp attached hw12
完成的
显示更多的6条评论
添加一条评论
3个答案
已选择的解决方案
Hi,
The watch needs to be connected (paired) to a mobile phone so that it can 'sync' the time with the phone.
What type of phone are you trying to pair the watch with?
If it is an Android based phone the OS of the phone needs to be Ver.4.4 or higher. It will not function correctly with Android versions lower than 4.4.
If it is with an iPhone then the OS version of the phone needs to iOS7.0 or higher.
Here is a link to the User Guide which explains how to connect to a mobile phone and how to sync the time.
https://fccid.io/pdf.php?id=2991005
这个答案有帮助吗?
得分 8
11条评论:
Thank you Jayeff. Actually, earlier in the evening one of my phones, that has no SIM card bit that I kept to use as a music and video player and for Wi-Fi use turned out to have the right Android and BT levels to sync perfectly with the two Chinese watches that were giving the wrong time.
完成的
z66 smart watch not set the correct time
完成的
please help me
完成的
I need help with a fb4e watch
完成的
I need help changing the time on a microware X2 smartwatch...no instructions in the manual..
完成的
显示更多的6条评论
添加一条评论
I had buy new watch which is said to be LD5 Smart Watch … And It is replica of apple design and it has option to change time in setting. So all the apple replica watch you can change watch time in setting after changing sysc time from AUTO to MANUAL.
这个答案有帮助吗?
得分 2
添加一条评论
Yesterday i spent about three hours trying to fix this problem. My watch 7 android is connected and it receives calls but a totally different time and date from my mobile.till i downloaded the app of the watch itself ,made an account , removed the watch from recognition of bluetooth of my phone while phone bluetooth is still on. The phone recognized watch thru QR code and i could control my watch thru phone, i even could download and design my own timefaces :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
garnacha 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 75
总计 63,492
