跳转到主内容
加入维修社区 - 创建账户
Model Number: M305D-S4829. Processor: AMD Turion™ X2 Dual-Core. Installed Memory: 4GB (PC6400 DDR2 800MHz SDRAM). Hard Drive: 250GB HDD. Display Size: 14.1" widescreen.
How do I undo an update
It worked fine until it updated. Now it is running so slowly I have waited over an hour for the control panel. How do I undo the update without the control panel? Can I boot in a safe mode? Can I boot from an external drive?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi, What OS is installed?
完成的
Thanks for everyone's help. I finally crashed the whole thing and I am waiting for a boot disc from Toshiba. It should have come with one but did not. Once it starts running again I will try these fixes.
John
完成的
添加一条评论
1个答案
已选择的解决方案
Try to clean your system instead of an Downgrade using the following tools:
After each run, restart your computer :
1 - ComboFix ( <= Windows 8 ) Close your Anti-virus before you lunch it !
2 - ZHPCleaner
3 - AdwCleaner
It will work fine & very fast after that ! :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
J Robbins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 240
