跳转到主内容
Repair guides for the Saitek X52 Pro HOTAS (hands-on throttle and stick) game controller. The controller was released by Saitek.
21 个问题 查看全部
Cable connector is not snug. Joystick does not fully connect to thrott
I have had two X52 Pro Throttle/Joystick combos. Both failed the same way...the cable connector on the joystick becomes a slack fit, which apparently prevents proper connection and communication to the throttle unit. I took a look inside and it appears that female connector would have to be replaced, and by soldering above my skill level. Any alternatives?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
The good news is that the connector is a standard Mini-DIN 6-Pin connector, so it's a widely available spare part.
The bad news is that there are no replacement parts available either officially or unofficially. Ever since Saitek was bought by Madcatz which was partially bought by Logitech, official support is essentially non-existent. You'll need to do the soldering yourself or get somebody to help you.
这个答案有帮助吗?
得分 0
添加一条评论
it is unfortunate design really.
It wiggles alot.
I recommend to open both and re-solder the wires they don’t hold too well in pcb. Mine were not properly soldered.
Don’t worry it is not hard soldering.
Just make a note of wire colors.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jratliffe 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 9
总计 1,688
