跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Why does home button when pressed affects the lcd
hi when i press the home button of the iphone 5s like double click it , the lower part of the screen above the home button seems to move the liquid inside the screen when it's being pressed each time i use the home button although no problem with the sceeen currently , does it affect the screen later on ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
Has the phone ever been repaired? Something below the screen is slightly putting pressure on it that causes it to show a rainbow effect. It may be your battery. It's common for batteries to bloat after a certain amount of use. I would open it up if you have a pentalobe screw driver laying around and see what the issue is. Let us know what you find out.
这个答案有帮助吗?
得分 2
7条评论:
yeah it has been repaired but i've checked it out it's not the battery everything seems to be connected well , i think it's the home button that's causing the pressure and the pressure seems to appear when you press the home button
完成的
Okay, good to know! So it narrows down to being a low quality LCD assembly or the home button connection to charging port is crooked causing it to discolor when pressed.
完成的
will it affect the lcd functionality later on because the lcd is still perfectly fine currently and something about this phone i don't wanna open it again to try and readjust the home button because when you try to detach the lcd from the board and put it back then switch the phone on ghost clicking starts even if the FPC connector is well placed on the digitizer flex cable
完成的
It won't affect the LCD after longterm use.
完成的
Is it the pressure on the glass or LCD that causes the rainbow spots?
完成的
显示更多的2条评论
添加一条评论
perhaps the tech who repaired your phone, left a screw or piece of glass (from your previous lens) and it's lodged between the LCD and some other internal component . pressing the home button down may be causing the pressure spot you're experiencing. i'd take care of it ASAP so no permanent damage is done to the LCD.
这个答案有帮助吗?
得分 0
添加一条评论
I am facing similar issue too. My iphone 5s has never been opened and this effect has started appearing since 1-2months. In my case whenever i press the home button, the screen right above it shows rainbow marks. I tried pressing at other points too to see if the screen reacts again but it showed those pressure marks at same point despite being pressed at different places on phone. When i press the back of the phone, then too pressure marks appear at same point. Is there a fix ?
这个答案有帮助吗?
得分 0
添加一条评论
Yeah and the LCD screen is damage cuz of the same thing
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bashir Abubakar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 2,677
