No video output, Cant change output mode, Can't hard reset.
Got a free PS3 that had three CDs stuffed in it and after removing them it was working fine (Stress tested, left running for about 6 hours and tried multiple game, also booted half a dozen times)
.. until I let someone borrow it and now there is no video output.
Have tried:
• Rebooting / resetting from wall, back switch etc
• Multiple monitors
• Multiple cables
• Using AV cables
• Changing video output mode (Holding down power button while AV is hooked up)(PS3 does not beep after holding power button for 5 seconds, after about 30-45 it will beep then shut off)
• Have Pulled apart a second time and checked all exposed plugs after taking top face plate off and nothing is out of place/not hooked up)
• Have cleaned contacts on HDMI port as well as possible.
I have a tech kit as I'm normally a computer / network tech so have many tools to sort this out.
Please help SOS
Are you sure your "Friend" didn't open your system up and take out a good part and replace it with a bad one?
由 Brian Reeder 完成的
It was a 14 year old girl. I'm %100 sure.
由 Omri Swarbrick 完成的
You can also just connect all video output options and then check them one by one till you find the one that is working.
由 Brian Reeder 完成的
Have the same problem tried the reset method by holding down red light power button for 5-10 sec NO BEEP... anyone figure this out?
由 J l l 完成的
