跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Replace it with 16GB To 32GB logic board
Hello Ifixit.
i Have 2 Iphone 5s
(Gold- M A1457) 16-GB
(SILVER-M A1530)32-GB
1.Can i Replace it with 16GB To 32GB logic board ? (Need Help)
2.home button Touch ID function will work or Not after replacing logic board ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If you transfer the logic board and Touch ID cable together, it should work. However, based on the colors of your phones, if you put the 32 GB board in the gold phone, you'd have to take the silver Touch ID sensor with it, which would create a mismatch. If you want to buy another 32 GB logic board to replace the 16 GB logic board, you won't be able to keep Touch ID functionality.
这个答案有帮助吗?
得分 2
1条评论:
I belive both sensors are white. Only the rim around the sensor is colored. Only in the case of the space gray is the sensor black
完成的
添加一条评论
Swap the home button over either the logic board and you will be fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kpo Nestle 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 5
总计 1,697
