跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
colored lines on screen?
My phone has colored lines on the screen and half the screen is frozen all because I dropped it. If I repair this at the repair phone place will it restart my phone?? Like would all my photos, contacts, notes, etc be on my phone after they repair this or will i need to set it up like a new phone again?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
No. Chances are, the screen is damaged and needs to be replaced. A simple, harmless repair. The only time you would lose all of your info, is if the Hard Drive was damaged.
这个答案有帮助吗?
得分 1
2条评论:
The data is stored on a NAND flash memory chip on the logic board, it's not a hard drive but it's a solid state drive basically.
完成的
I just say hard drive because its easier understand, and because SSD's and HDD's are both technically hard drives.
完成的
添加一条评论
My iphone 6 screen display shows pink/ blue/ purple tint with vertical lines. And the recent opened apps appears in the background with low visibility when its on home screen. Please help!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jay z 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 3,125
