跳转到主内容
Sony Xperia Z3 Compact released in Sep. 2014.
How to remove Oil marks from display
Hello Friends ! I have Xperia z3 compact..recently i spilled hair oil on its display...so it got some white marks on lower left corner..touch is working absolutely fine and so is everything.but i want to remove those white marks..is it possible, suggest all available option to remove those marks.... please help its really urgent guys
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The issue you're running into is, the oil seeped into the backlight behind your LCD display. The only way to remove the oil is to get your backlight replaced or your entire LCD assembly replaced.
这个答案有帮助吗?
得分 0
2条评论:
Thank u Friend,, but there must be some other way as well...can u please recommend any other method bcz at last i will replace whole lcd if nothing works out
完成的
Unfortunately, since it's an oil based liquid, I don't think you'll be able to dry it out. :( Good luck to you! If you need help with a repair, we accept mail-in repairs at our shop!
完成的
添加一条评论
添加你的答案
mail4dueds 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 134
