跳转到主内容
The Moto G is Motorola's economically priced phone. It has all the features one could want in a smart phone, for half the price. Model numbers XT1032, XT1033, and XT1036.
Fastboot Erro "Fastboot Reason: Falied to inicialize partition table"
SPEAKING FOLKS Firmness ? STAND WITH A MOTO G 1 GENERATION , I WENT TO UNLOCK The BOOTLOADER AND NOW IT ONLY ON THE Fastboot SCREEN WITH THIS NEXT ERROR ,
" Fastboot Reason: falied to boot partition table " Already Tried Installing A ROM BY Fastboot NOT THE RIGHT OF THIS NEXT ERROR IN ALL
THE COMMAND LINES "failed (remote) " . THE FIRST COMMAND " flash partition mfastboot.exe gpt.bin " IT 'S THE FOLLOWING ERROR ,
''target max-sparse-size: 256MB
sending 'partition' (32 KB)...
OKAY [ 0.024s]
writing 'partition'...
(bootloader) This may take a few seconds, if a
(bootloader) different partition table is being
(bootloader) flashed since we need to backup
(bootloader) and restore a few partitions
(bootloader) Flashing primary GPT image...
(bootloader) Failed to write primary GPT.
(bootloader) Failed to program partition table
FAILED (remote failure)
finished. total time: 5.277s'''
AND IN OTHER LINES OF COMMAND "FAILED (remote failure ) ," JA USED RSD Lite , have USED THE COMMAND " mfastboot oem fb_mode_clear "
BUT WHEN WILL UNLOCK The Bootload THE NEW ERROR SOMEONE I COULD HELP ME ?
I tried to downgrade to 4.4.4 kit kat most still can not install nor a firmeware on bike g and also tried to install the 5.1 version of the same thing.
desulpe the English but I'm from Brazil I'm still learning.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
Fiz um vídeo com uma solução para este problema!
Siga o link: https://youtu.be/hmfu6Jx9E1M
这个答案有帮助吗?
得分 0
3条评论:
ja vi esse video n adiantou nada mas meu celular é um moto g7
完成的
to com mesmo problema meu tbm e um moto g7
完成的
mesmo problema no meu moto g7 power, depois q eu tentei instalar uma custom rom ele deu hard brick e nao consigo restaurar ele
完成的
添加一条评论
yes this phase me on moto
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eliseu Oliveira 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 6,353
