跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
Assembly Cable #3
How do I put Cable #3 back into the socket?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Thanks for the responses' exactly what i needed
完成的
Great!
完成的
添加一条评论
3个答案
最有帮助的答案
What you need to do is take the cable labled #3 with some tweezers and very carefully insert it into its outlet but make sure that the little latch is flipped up. when you get the cable in there flip down the latch and it will be locked in there. after that you can plug in #2 and then #1 and then close the device up and check to see if it works
这个答案有帮助吗?
得分 1
添加一条评论
Make sure the plastic clip is pulled back and with your nail or a spudger push the cable back into the socket and flip down the black plastic securing clip.
这个答案有帮助吗?
得分 0
添加一条评论
For a pic, please see this question.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Al Winchester 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 20,421
