Wifi siginal iPhone 5c
I just had some repair done to the board and when I got the phone back the wifi only works when I am within 3 feet of my wireless router. I was wondering if you think maybe the antenna has loose connection or something?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 116
Probably wifi antenna capable not plugged in. If I'm correct it plugs under the board at the to left like the other iPhone 5 and higher.
由 Ben 完成的
I'm going off memory, but I also believe there is a small piece that goes up there as well. Its a little clip looking doohicky that is easy to misplace or not align correctly.
由 Josh W 完成的
It sounds like your wifi antenna maybe loose . I would return it to whoever worked on it.
由 Deleted 完成的
