跳转到主内容
This Power Mac G4 has Mirrored Drive Doors.
80 个问题 查看全部
No chime, black screen, fans all running?
I push the startup button on the computer, I hear a motor click or something, and then get no chime, no image, then after about 10 seconds all fans come on. The screen is an older 23" HD Cinema display. There is no paperclip hole in the optical drive to startup from OSX disk. I believe I lost the image when I reseated the Graphics card.
I've replaced:
(2) Hard Drives.
Battery
Logicboard
DP CPU
I've reseated or unplugged and plugged back in:
Computer speaker
RAM in all 4 slots
Graphics Card
Battery
I've reset the:
PRAM
Battery
Logic Board
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
This is about the eighth question on this same machine. Try starting up holding the mouse button down to eject the disk drive.
这个答案有帮助吗?
得分 1
5条评论:
Yes I know. It takes a while between ordering parts to try solution. I'm still considering upgrade, but want to get the computer working first. I have followed, pretty much everything suggested except starting up from OSX disk, which I can't do unless tray is open. Depressed mouse, pushed start up, tray did not open.
完成的
Took out optical drive, put OSX disk in tray, nothing. Hooked up firewire cable to Powerbook G4, not recognized as remote hard drive.
完成的
Good beginning +
完成的
I've never seen a full sized disk drive without an eject hole. What is the brand and model number?
完成的
I don't know the model, when I took optical drive cage out, there was an eject hole I could use, the way it was built with the hole pretty low on unit, the hole was covered by the frame of the (2) mirror doors. It is not the original optical drive, but has been working fine for several years.
完成的
添加一条评论
boot with only one chip of ram and try using different ram.
这个答案有帮助吗?
得分 1
2条评论:
完成的
Took (3) RAM chips out, left (1) in, no change. Will locate a different RAM chip and see if that works.Will have to order, so will take a few days. Mr. Mayer also suggested this previously.
完成的
添加一条评论
Lots of discussion with this issue but no one ever say, "i have a fix".
Has anyone ever solved this problem?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
R Michael Olexo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 2,904
