跳转到主内容
Also known as EOS 600D and released in March 2011, this camera can be identified by its SKU (SKU:5169BO32). This camera is a Canon Digital SLR with 18 megapixels.
52 个问题 查看全部
Canon Rebel T3i drop damage on LCD
I'm assuming I can diagnose and repair this camera without a lens attached.
Canon EOS Rebel T3i was dropped. When I insert an SD for the first time, the camera creates the DCIM\EOSMISC directory and creates the M0100.ctg file inside it.
The screen generates a backlight, but no image. Pressing Menu (and perhaps the Info) button seems to toggle the backlighting (and/or image).
The screen actually looks intact - I fail to see cracks.
I'm thinking about three parts that could be bad:
1. Screen
2. LCD Display Screen Board PCB DH2826
3. Blue cable connecting the body to the Screen Board PCB
I know the Screen and Screen Board are available for purchase separately. I hope the blue cable is still intact. What else can I do to pinpoint which part(s) need replacing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The easiest fix would obviously be to check the ribbon cable. After all, the cable might have simply become dislodged. My advice would be to start with the easiest fix and work your way up to the hardest.
Did you try taking pictures with the camera after you dropped it? If the camera can still properly take and save the photos, you would at least know that your shutter box, sensor, and logic board aren't damaged.
这个答案有帮助吗?
得分 0
1条评论:
I got around to working on the camera again. I reseated both cables attached to the LCD. There is no change in behavior. Might pull the trigger on a replacement LCD but still wondering if LCD Display Screen Board PCB DH2826 is defective.
完成的
添加一条评论
添加你的答案
lkvee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 7
总计 254
