跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
iPhone 5s doesn't show that it's charging when its off
I was repairing an Iphone 5s. After I took the bottom screws out and lifted the screen,I was in the process of removing the metal shield from the battery cable.I used metal tweezers instead of the plastic sponger.Big mistake because I saw a small spark fly. I detached the battery,then held the power button for 30 seconds before reconnecting the battery.(In which the dead battery signal came on the screen).I then disconnected the battery and went moved onto the screen repair. Once I put the phone back together,I put the phone on charger.(At this point it is showing the dead battery signal.) I left it there long for about 5 minutes before the phone booted itself up. I tested everything to make sure everything is working, then I let it charge about 20 more minutes while connected to my laptop.The problem that I'm having is,the phone works fine,but when it is on the charger and turned off,it gives no sign of charging. If the phone is on while on the charger,it shows the lightning bolt by the battery at the to of the screen signifying charging in process. But when it's off,(though it's charging) it shows nothing but a black screen.Sorry so long, I just wanted to make make sure I included all details. Any help would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
So it charges, it just doesn't show a charging icon when the phone is off?
完成的
Yes,that is correct,Josh
完成的
Funnily I always use nails to unplug connectors. Always worked out the best for me. The only time I ever use a plastic spudger is if there are so many ribbon connectors to unclip like htc one m9.
完成的
添加一条评论
2个答案
已选择的解决方案
Probably blew a filter. Its not an easy fix and its not a cheap fix to have someone else do. If it were me, I'd leave it be as long as its charging, holding a charge and not heating up
这个答案有帮助吗?
得分 1
2条评论:
That would be a motherboard repair???
完成的
Yes.
+chartoletmepost
完成的
添加一条评论
My s6 does the same thing but it's new is it supposed to show a charging sign when it's off
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ungandua 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,867
