跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Mic only works when in a call
i have somebody who complaned there mic didnt work sometimes like when on a call the other people couldent hear them, so naturly i replaced the microphone. to test if it worked i called someone and it worked both in speaker and not, however if i open a video recording app or the voice memos the mic picks up nothing. it is jailbroken btw. any ideas why this could be???
also if i yell into the mic loud enough it will record a buzzing sound but anything not as loud will not make any noise
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
anybody got an idea?
完成的
What happens when you plug in a headset with a mic on it? Does it work then?
完成的
添加一条评论
1个答案
最有帮助的答案
I would try it with a headset microphone first. But if that does not work it could be a problem with the software.
Double check that the mic is installed correctly first and then reset the phone through iTunes if nothingness wrong with that. The only problem is this will remove your jailbreak, and if you rely on an unlock this will remove it. Unless you have a carrier unlock.
I had problems with things when I was jailbroken, but they all went away after reinstalling the firmware.
Hope this helps :)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ric 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,633
