跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1169 个问题 查看全部
wont turn on after diy repair
after replacing screen myself Iphone speaker was not working so I was going to check the #3 connection and forgot to turn off the iphone before taking apart. checked all connections multiple times, have waited 5 mins for reboot several times. Did I fry the iphone by not turning it off before taking apart? IF so can I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
I also have the same problem. I repaired my iPhone's cracked screen and after reconnecting everything it wont seem to turn on. I thought I might have broken the LCD but even if it were broken it would atleast glitch or something
完成的
hey, i did tear down too of the top glass part on my iphone 3g and once i put everything back together, i couldn't turn the iphone on (or it seemed that it was off). But once I plugged in to charge it, the screen started working. What could be the reason? Thanks..
完成的
this is a very common question, and i have yet to find a detailed answer on this website. Everyone seems to ignore it, and it's torturous because i have the same problem. Repaired everything fine. Connectors are in place...phone's display will not work. Itunes charges the phone, and I can toggle the vibrate/ringer switch to make the phone vibrate...but that's it. PLEASE HELP! Many people have asked as i've searched for this for hours upon hours.
完成的
is the phone actually charging? if not, then there seems to be a connection problem. Try and see if the battery is actually connected. Tell me what happens after you do that. Let me help you
完成的
添加一条评论
4个答案
最有帮助的答案
Hi everyone,
I changed my LCD and charged the phone fully but the screen stayed black. The iphone alarm clock kept ringing so I knew the phone was working but could not turn it off and still had the black screen.
I reopened the iphone as advised & found the connector 1 unplugged. I replugged it. The screen was still black after that, so I tried the home + sleep button for 10 seconds and the apple finaly appeared ! It's working perfect now ...
Hope this will work for you & good luck
这个答案有帮助吗?
得分 2
2条评论:
don't mean to bump an old topic but i +1'd roxane m's answer because it worked for me.
完成的
disconnect and connect again the connectors for the screen/LCD
完成的
添加一条评论
reset the phone by pressing and holding the home and sleep button. This worked for me.
这个答案有帮助吗?
得分 1
添加一条评论
This happened when I added a custom silver housing, all you have to do is run BlackRa1n and when it restarts, the display will work.
这个答案有帮助吗?
得分 0
添加一条评论
I tried all of the above and none worked and after trying a new plug/usb cable i was conviced it had something to do with the battery after a couple of hours of unpluging and repluging 1,2&3 conectors at the top i found two small metal strips which one had bent at the bottom which conects the screen to the battery i think anyway i bent it back put it back together and it turn straight back on hope it helps
这个答案有帮助吗?
得分 0
1条评论:
"I tried all of the above and none worked and after trying a new plug/usb cable i was conviced it had something to do with the battery after a couple of hours of unpluging and repluging 1,2&3 conectors at the top i found two small metal strips which one had bent at the bottom which conects the screen to the battery i think anyway i bent it back put it back together and it turn straight back on hope it helps"
Can you take a photo of these metal strips ?
I have the same problem but I dunno of what metal trips are you talking about.
Thank you
完成的
添加一条评论
添加你的答案
sariah 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 6
总计 13,530
