跳转到主内容
Released May 2015 under android operating systems. The Iconia One 8 is a Wi-Fi capable tablet equipped with 9in screen and 1200x800 resolution.
8 个问题 查看全部
Where can I buy digitizer touch panel for Acer Iconia One 8
The digitizer glas on my Acer Iconia One 8 B1-830 is cracked. I already took the tab apart successfully. Desperately seeking the internet for a replacement part, but without any findings.
Problem is: model B1-830 is different from B1-810 and B1-820 and also different from other 8 inch acer models.
I need a digitizer glass for Iconia One 8 B1-830
Any help welcome
best regards
Harald
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
最有帮助的答案
This is the picture of my touch digitizer. In the meantime I found out, that the display and touch screen of Iconia One 8 B1-830 is identical to B1-820. I already ordered a spare part of model B1-820, still waiting for it.
Harald
这个答案有帮助吗?
得分 1
3条评论:
Hi, I was wondering if you fitted the 820 screen to the 830 & did it work properly. I have to fix my nephews tablet so was wondering if yours worked. Thanks
完成的
Unfortunately, the display+touchscreen of B1-820 did not work in my B1-830. It is physically identical and the connector looks exactly like my defective one. When I assembled it, the led-backlight turned on, but the display stayed black. No picture at all, it didn't work! Don't know why. It looks like B1-820 display is not compatible with B1-830.
完成的
Thanks for that. There will be no need for me to try it out. It is actually cheaper to buy a new one than it is to get a replacement screen. I find that crazy, but there you have it.
完成的
添加一条评论
I did manage to find where you can buy the part for your specific model tablet, but holy cow its expensive! Here's the link to the part you require..
http://www.ebay.ca/itm/WHITE-ACER-ICONIA...
Hope this helps you!
这个答案有帮助吗?
得分 0
2条评论:
Thanks for your help!
Unfortunately, although the title suggests, it is a B1-830, this part is not the correct one. The connector of my digitizer is in the middle of the bottom line, not at the edge. The connector itself looks the same as mine.
The price is ridiculous, because a new Iconia One 8 costs less than 127 Pound!
完成的
hi friend,can you share me a picture for b1-830 Touch screen?maybe we can help each other,my email jackyhetabparts@yahoo.com
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
Mine is iconia one 8 B_820 how much does it cost and how can I order it
这个答案有帮助吗?
得分 0
添加一条评论
I am from Ghana and I bought this item from UK in 2015
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harald Keys 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 1,367
