跳转到主内容
加入维修社区 - 创建账户
所有HTC发布的Windows Phone的维修指南。
Windows was unable to complete the format
Hello, friends! My HTC phone SD memory card recently just asks to format when it was used on my Windows 8 computer. However, when I click Yes to format SD card with my computer phone SMS, games, files and photos, windows just says windows was unable to complete to format? Honestly, I have used Google to search for the related windows unable to complete the format error problems and also am wondering to select a formatting program? Do you have any recommendation? Is such software helpful for my case? Thanks for any suggestion here!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi, you can just format your SD card by Command Prompt :
1. Insert the USB Flash drive into your laptop or computer; wait until it will be detected.
2: Open Command Prompt by following this flow: Start →Accessories →Command Prompt or Start → Run → type “cmd” → Enter
3: Assuming your USB flash drive is assigned the letter “F”: type the following command in the Command Prompt with the following:
format F: /fs:FAT32
If you would like to convert the file system into NTFS, FAT, exFAT, just change FAT32 to the target file system.
Step 4: To continue or stop the formatting process, press Y (for Yes) or N (for No).
I think it’s no need to use the program, it’s not safe sometimes, you can just use the command on pc to complete your format.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Reo0Yu0 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 40
总计 355
