跳转到主内容
Why logic board chimes when pin is touched with probe?
Hello Guys,
Maybe one of you can help with this unusually weird problem I have with my 820-2330 logic board. The board powers on, but won't chime or boot until I touch a couple of specific pins on chip U8900. This is what happens exactly; when the board is powered on and I touch pins VO or OCSET on U8900 the board then chimes and boots normally. It is driving me crazy trying to figure this one out. At first I replaced U8900, then I replaced both FETS, then I replaced the Critical caps after the inductor all to no avail. Any help would be appreciated.
Thanks,
Roger
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Look for an open trace or bad component attached to one or both of the pins you mentioned. If an input pin is not connected, touching it with a logic or scope probe connects it to ground through the probe circuit, thereby giving it a logic low (“0”)signal.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Roger 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 59
