跳转到主内容
Repair information for the Brother MFC-J6920DW wireless, multifunction inkjet printer. Model number: MFC-J6920DW. First available on Amazon in September of 2012.
Prints and Copies are coming out with jagged lines/texts
My prints and copies are coming out with jagged lines/texts
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Thanks for your response Jayeff. However, I did try this several times but it made no difference.
完成的
Re-aligning print heads doesn't solve the problem....
完成的
Hi @ Tracy Lloyd,
Try cleaning the paper transport rollers in case they are causing the paper to stick and not feed through smoothly
完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
Perform a print alignment check of your printer.
Here is an image that shows what to do.
这个答案有帮助吗?
得分 2
添加一条评论
You should run the cleaning cycle a few times I had an issue that there was lines and magenta wasn’t coming out the print head is just clogged
这个答案有帮助吗?
得分 0
1条评论:
I ran the cleaning cycle several times and it didn't help. Does the printer head need to be changed?
完成的
添加一条评论
添加你的答案
Khemchand Ramcharan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 23
总计 4,839
