跳转到主内容
Repair guides and disassembly information for Lenovo's 3rd-gen ThinkPad X1 Carbon laptops.
8 个问题 查看全部
Lenovo Thinkpad X1 Carbon Gen 3 LVDS fuse blown? Display blank
Replacing cracked screen on 3rd generation Thinkpad X1 Carbon. Cust used for a while with cracked screen and then it went black after a few days. Installed new screen, still black. No image at all. System still works fine when external monitor is connected however checking in device manager built in screen is not detected at all so it's not just backlight. Thinking maybe a blown fuse or issue with LED driver? Can't find schematics for this motherboard.
Update (09/12/2016)
Motherboard part numer 448.01406.0011. Lenovo FRU 00HT361.
Pics of LVDS connector and bottom side of motherboard underneath LVDS
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
For me it was fuse f3. After creating a short cut it works. Really important to unplug the power while changing displays.
这个答案有帮助吗?
得分 1
1条评论:
Hello @lucek4, may you suggest the f3 fuse location. Thx you
完成的
添加一条评论
Good Day!
I have exact same problem after replacing cracked screen, I have x1 gen 2, almost the same smd fuses, for me the fuse F7 was blown i replaced it but still black screen and the fuse is blown again right after replacement, Can you read the number on that 8pin IC next to the fuse something like F28 or something, i need to replace it but couldn't find the part number as i can not read it, I think it is the power regulator or driver for back light. i checked all surrounding parts like diodes and capacitors all good only the fuse is blown which is connected direct to this IC, so i think it is short or blown, i see picture with torch on screen but no backlight,
thanks
这个答案有帮助吗?
得分 1
2条评论:
Thanks Khizar for this post,
I would appreciate if you add a picture to both areas of the F7 and Pin8
I could not locate them.
完成的
添加一条评论
Thanks for your feedback. I have made a seperate thread. Here is the link.. you can find fotos there.
No backlight with blown fuse under lvds connector
Thanks for your help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
managerharry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 4,245
