跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 个问题 查看全部
Xbox one S - Loud fan noise
Hi,
I´m recently bought a 2tb Xbox One S and it´s fan sound like something is hitting the blades. Any guess about how to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
6条评论
Hi,
I´m glade that my "experience" could help you. It´s really a shame MS quality control.
完成的
Hey the same is happening to me too, it's past the warranty and I can't return it so which type of fan should I use in replacing it
完成的
Austin, search for a PWM fan. I used a Corsair one, working better than The original.
There several youtube guides to change The fan, its easy enough to do at home, just take care and not hurry things.
完成的
Is there a illustration to show one how to perform this fan replacement? , iIfound a Cougar Vortex PWM 800-1500RPM fan
完成的
I don´t any illustration, but is working fine to me.
完成的
显示更多的1条评论
添加一条评论
6个答案
已选择的解决方案
Hi Yan,
It´s really simple to change the bearing, you can remove the fan without have to remove the heatsink. The fan is almost the same, but it dont fit well, because the height of the one s. I suggest you change the fan to a custom one, like corsair or another pc fan, it´s really simple, look for guides in Youtube, i got better results changing the fan instead of the bearings.
Hope it could help you.
这个答案有帮助吗?
得分 1
7条评论:
I saw on youtube peoples saying that after changing the fan with an custom one they have problems with overheating. Is that true?
完成的
I don´t have any problem. It´s important that the fan is a PWM, so it can change the speed of the fan when is necessary.
完成的
And when you are gaming you are sure that your fan increases speed? And your custom fan is focused for air flow or static pressure?
Thanks!
完成的
I hear it´s getting faster (and louder), so yes.
完成的
Thanks for the info! Where did you get the replacement bearings, are they a particular type?
完成的
显示更多的2条评论
添加一条评论
Has anything fallen into the fan? Anything unusual happen to the unit? (Like getting knocked over, hit, etc.) At this point, I would recommend sending it in on warranty. Since it was only just released, you should be able to get it fixed for free under warranty, and you won't risk damaging it more opening it up.
这个答案有帮助吗?
得分 0
添加一条评论
Hi Ben Eccles,
I kind of fixed the fan noise. Last night I open the entire console and removed the fan, I discovered that the sound was coming from 2 crap bearing´s inside the fan, changed them and said goodbye for the noise, at least until now.
Tks for the help.
P.S: Sorry about my poor english, I´m from Brasil and I´m a little rusty.
这个答案有帮助吗?
得分 0
1条评论:
No worries! Glad I could help!
完成的
添加一条评论
Hi ricardo
I got the same problem, is it easy to change the bearing? (can i dissemble the fan without removing all the heatsink?)
I was thinking to change the fan myself but i don't know if the Xbox One fan is compatible with the One S fan.
Thx
这个答案有帮助吗?
得分 0
添加一条评论
Thx for your help, i have changed the fan, i've used a PWM 120 mm fan.
Now the Xbox is quiet, the hard drive is louder than the fan :)
It's a shame for Microsoft quality control, a lot of people got this problem (and some are thinking the buzzing noise is normal)
这个答案有帮助吗?
得分 0
12条评论:
完成的
No overheating for me with an Akasa AK-FN064 fan
完成的
And when you are gaming the fan is increasing the speed?
完成的
and how did you solve with the conector? what are the pins for controling fan speed?
完成的
For me it was a little trick, but tested the cable until discover. If you dont set the cable in the right way, it will be set in full speed all the time, even if its on sleep mode.
完成的
显示更多的7条评论
添加一条评论
Hello!
What typ of fans are you guys using? Or rather from what manufacture? Want to be ready to change it if i get the same problem when i recieve my One S.
这个答案有帮助吗?
得分 0
1条评论:
I´m using a PWM fan from corsair. But if you receive yours Xbox One S with the problem, send it back and exchange for a new one.
完成的
添加一条评论
添加你的答案
ricardogranjaadv 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 15
过去 30 天: 25
总计 34,539
