跳转到主内容
Keyboard fpc flap broken
Hello
I have a Toshiba laptop.
The fpc connector that holds the keyboard ribbon is working fine, but the plastic flap that retains it in place is almost broken
I am sure it's possible to get a replacement fpc, get the flap out and put it in place.
The flap is the kind of flap that you slide out and then put the flex in, then slide it in again.
Is this possible and how could I get it?
I would say it's similar to the black flap of this one in the image below
http://jdllh.com/en/uploaded_images/1381...
The connector has 34 pins and it's probably the size of any other keyboard fpc connector.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I am looking on Aliexpress at some fpc keyboard connectors, but all of them are the lift up style ones
https://www.aliexpress.com/wholesale?cat...
Do you know where I can find the ones that you slide it in and out so I can just replace the flap on the faulty connector in the motherboard?
Thanks!
完成的
I found a good screenshot here. This looks pretty much like mine!
http://www.laptoprepair101.com/wp-images...
完成的
添加一条评论
1个答案
已选择的解决方案
HERE Are some I found Hope It Helps!!
这个答案有帮助吗?
得分 1
3条评论:
Hello
Thank you!
Those were from the US so the shipping was expensive.
I also found these which should be similar
http://www.ebay.es/itm/10-Pcs-Single-Row...
Do you know if it's possible to take the flap out so you can put it on the one on my motherboard?
Thanks!
完成的
I have just replaced the flap before it Just takes some patience
完成的
Thank you I will order them and see how it goes. Thanks!!
完成的
添加一条评论
添加你的答案
Alberto 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 397
