跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Home button is unresponsive
So I have a problem.
I repaired my display on my iPhone 6 and I know how to do it perfectly because I worked in a repair store 6 months ago for 2 years and some more experiences. And suddenly now my home button doesn't work when my phone is sleeping. I can use my power button to wake it and then my home button works perfectly fine. Even when I put it back to sleep, it is working but only for the first 5 seconds. When my charging cable is plugged into it, it works like 60-70% of the time even when it was off for an hour or more. Also, the touch ID isn't working anymore. Home button was never replaced.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Either the home button extension cable is partially damaged or teared (really hard to tell but it's easy to damage) or the home button cable itself on the home button is damaged.
Best bet is to try another home button extension cable first (I buy with the metal shield to avoid the hassle of trying to install the home button cable without it pre-assembled).
Here is the part I am talking about, ignore where it says replacing the cable stops touchID from working, it is false and only applies to replacing the actual home button itself.
iPhone 6 LCD Shield Plate with Sticker and Home Cable
This part fits between the LCD and the rest of the phone's internal parts and includes the home button link cable.图片
产品
$26.99
这个答案有帮助吗?
得分 3
4条评论:
Has to be either a partial tear on the home flex, home button, or possibly debris in the home button connector.
My guess is its a small tear somewhere on the home flex. Its super easy to tear if you aren't careful. Heck...you can tear it even when you are careful.
OP: replace the flex and you should be good.
完成的
Sorry for the long response time. I was busy with lots of stuff. Anyway, I ordered those parts and the problem was solved.. partially. Now it's saying that it's unable to activate the touch ID on this iphone. :/
完成的
go into your settings and remove touch ID from iTunes purchases. Reboot your phone and try Touch ID again.
I've heard it reported that this fixes it and I'd like confirmation one way or the other.
完成的
I can't even turn it on. Already made a reset on all my settings but it's still not working
完成的
添加一条评论
I am 90% sure you damaged the ribbon cable or the connection housing in the odds is the ribbon replace the home button and it should be fine if not then the connection between the ribbon housing on the main board and the board is damaged and you are up a creek with out a paddle
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shabir 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 268
