跳转到主内容
加入维修社区 - 创建账户
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Programming Code displaying on startup sequence
An ipad 2 that had been significantly damaged on the corner. Prior to repair there was no screen sensitivity. I changed the screen and repaired the corner. Once the screen was on the software defaulted to the voice over control. I deactivated the voice over control and everything was working well. This morning, I turned the ipad on to check how it was going after charging it, and the programming code came up and it would not go past the Apple Logo. Since then I have done the following;
1. Hard Reset
2. Connect to itunes and do an update
3. Run an itunes diagnostic on the connectivity of the ipad and
None of these have worked and it will not go past the initial setup phase.
Can anybody shed some light on this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Reball flash ram ......
这个答案有帮助吗?
得分 0
1条评论:
What does that mean?
完成的
添加一条评论
添加你的答案
Natasha Rogers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 111
