跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
iPhone 6 disabled, emergency call one, TOUCH id no go
Took my phone screen cracked, got moisture in it, screen began to glitch and got to the point of really bad distortion, it began to malfunction and make calls out, bring up random applications with out command. Phone became disabled. Took it to Batteries plus and paid 122, guy said the battery was swollen and strip is red verses white, he didn't want to take out the battery until we knew for certain that there was no internal issues.
Touch ID isn't working after the screen replacement. Now that screen is fixed iPhone is asking to be connected to iTunes with iPhone disabled screen, when I swipe it only gives me emergency dial pad, so I cant enter passcode for iTunes to allow sync! How do I fix this?!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
Do you have a computer that has iTunes on it that you have already synced with in the past? If so then you can use that to restore through iTunes without needing to sync it again.
Otherwise follow the instructions here : https://www.theiphonewiki.com/wiki/DFU_M...
This will put your phone into DFU mode which will allow you to restore the device through iTunes without syncing it. Once you have restore the device you should be able to set it back up.
这个答案有帮助吗?
得分 1
2条评论:
OP: DO UPDATE FIRST, it might remove the disabled without needing to restore the phone which basically wipes anything. Use restore as last resort.
完成的
Thank you! I was able to save it and fix the screen. :)
完成的
添加一条评论
home buttun not working,touch id not working,how to unlock my disabled iphone with emergency
这个答案有帮助吗?
得分 0
添加一条评论
please help me how to unlock my phone with emergency number
这个答案有帮助吗?
得分 0
添加一条评论
sir,when i connected to lap the usb also not connecting,help me sir
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chandelle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 971
