跳转到主内容
The Motorola Xoom is an Android-based tablet computer by Motorola, introduced at CES 2011 on January 5, 2011. It is the first tablet to run Android 3.0 Honeycomb.
Why won't my tablet take a charge.
I changed the battery with a brand new one cause the old one wasn't holding a charge any more. Now I can't get the new battery to charge at all. I checked the charging port to see if it was damaged but it looks good. Do I have to rest the table back to how it was when I got it ? Don't know what else to do.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
please check the another outlet . If all else fails just walk into a Verizon store and tell them what's going on. They are usually pretty helpful in getting a replacement device for you
这个答案有帮助吗?
得分 0
添加一条评论
if your tablet has a micro usb charging port , they tend to get a bit touchy after a while. you might try and place the tablet on a flat surface and put something under the plug to apply a little pressure on the connector . trying it with the tablet face up or face down. those jacks seem to all get touchy after a while.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 840
