跳转到主内容
27“显示屏,分辨率为2560 x 1440像素 Thunderbolt&MagSafe电缆附件
What is causing barely seen vertical line
I have a thunderbolt display that recently showing a barely seen vertical line (see picture) some kind of noise, there is nothing else wrong, neither color or picture.
I was wondering if its noise from power supply or logic board or T-CON board, the lcd is LM270WQ1-SDB3.
I dont have a schematics and can not find it either by googling (checking probe point with oscilloscope ).
link to picture:
https://s9.postimg.org/6aczv1z2n/DSC_000...
thanks in advance.
Ted :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The ribbon wire inside of the monitor may need to be "reseated". Basically unplugged and plugged back in. Before you go through all that trouble try to eliminate ALL electro-magnetic sources of interference. If it persists, it may be the ribbon wire.
这个答案有帮助吗?
得分 2
2条评论:
How about a link to how to do that?
完成的
http://google.com <-- try this one, John. :)
完成的
添加一条评论
添加你的答案
ted lindsay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 555
