跳转到主内容
The Samsung Galaxy Tabs are Samsung's flagship tablets that compete with iPads.
375 个问题 查看全部
Seeing the Battery But charge symbol has an X through it
Hi to all
I have a Samsung Galaxy SM-T810, Came into the shop with a cracked Digitizer. No worries sent away for a new one. Started the assembly and they are very easy to do. Put it together to test it and noted an "X" through the Battery Symbol. That means, not Charging, but why ?
I plug in the charge cable and it sees it but will not progress past the 20% that it is charged too
Has anyone seen this before and will a factory reset fix this?
New Battery maybe ?
I feel I would probably go for the first but it also could be a charging system fault........ not liking the sound of that
Would like to know your views Please
Cheers!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thank you for the answer, just to add to it. I left it on charge all night and in the morning it was fully charged and the "X" had gone,. But now I know the next time this happens ill know :)
完成的
添加一条评论
1个答案
已选择的解决方案
I get the the red x on my battery status symbol when charging now.
I dont know why.
But if i usea low amp charger the battery drains on charge.
If i up the amperage the x remains but the phone charges.
This is since the software update.
This could be coincidence.
The phone is a year old.
Could be battery fault.
But the battery when charged holds it well.
The red x does not necessarily mean not charging.
这个答案有帮助吗?
得分 2
1条评论:
I have a red x does that mean it doesn't charge or when it turns off will i not be able to open my i pad?
完成的
添加一条评论
添加你的答案
Charlie Clemett 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 29
总计 3,257
