跳转到主内容
Repair guides and troubleshooting information for microwave ovens.
761 个问题 查看全部
Capacitor keeps failing, Whirpool microwave doesn't heat
I have changed the capacitor 2 times but after a few days of heating, the microwave stops heating.
Any idea what could be going wrong? The diode tested fine. And if I put a new capacitor, it works for few days - so I guess that rules out Magnetron and other switches n stuff. So a faulty circuit board probably?
Has anyone had this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
mrchief,
Just because it works again after a capacitor replacement does not mean the magnetron isn't failing. It could possibly be that the magnetron is burned out bad enough that you are over-driving the capacitor to blow out.
There should be more than one cap in the power circuit for the magnetron driver circuit. It's a turned circuit, so check out an iductor loops in there as well for visible damage to their insulations.
Even with a schematic and some thorough circuit testing, finding an impedance/reactance mismatch would be pretty difficult. Your hint might be that the cap is either getting overvolted, or draw much too much current.
Hope that helps, best of luck
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mrchief 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 951
