跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Touch IC chip replaced but now the WIFI chip needs replacing too!
Hi guys, recently purchased an iPhone 6 with a known touch fault. i have had the touch ic chip replaced and everything is now fine but the wifi chip is not working ither!
I've been told there's a large risk of completely killing the phone by also
replacing this chip. Is this true?
Please note: the wifi was faulty before the touch ic had been repaired. The fault is 100% the chip and not the antenna.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
Anytime you apply heat to replace an IC, you risk damaging the phone. The WiFi IC is no different than any other IC in that regard. It is sealed with an epoxy underfill which makes removing this IC more challenging so proper procedures have to be taken.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Al Burg 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 108
