跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Stuck on Apple Logo but battery low
I have already been through this thread
Stuck in continuous apple logo loop, turns off when cable removed?
Unfortunately, my situation is compounded by the fact that my phone has no power left. Thats how it started in fact. So you plug in the phone and it shows the battery icon but only for about 5 seconds. Then it immediately tries to boot despite not having enough power. So it goes back to charging mode of around 5 seconds and repeats. It seems its trying to boot without enough power.
So even if I try the above steps, it just goes back to battery icon mode for 5 seconds and never even tries to boot up.
Any thoughts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
If the charging port pins don't look damaged, clean the charging port if the charging cable does not plug in fully. Otherwise you probably need the battery replaced.
完成的
Its trying to boot before the battery gets sufficiently charged.
完成的
Are all of the components near the battery connector on the logic board there? If one of them are missing that probably is what is causing the problem as it's stopping it from reading the battery correctly.
完成的
添加一条评论
2个答案
已选择的解决方案
The problem was with the battery. I got it replaced. All good now.
这个答案有帮助吗?
得分 1
添加一条评论
it could have aproblem with the charging port. try checking the connections on it.
这个答案有帮助吗?
得分 0
1条评论:
Nope not a problem. It s charging when you plug it in. The problem is it tries to boot without charging enough. It tries booting a few seconds after charging begins but it should be waiting much longer.
完成的
添加一条评论
添加你的答案
stuart 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 183
