跳转到主内容
加入维修社区 - 创建账户
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
iPod Touch 5th Generation
So the problem with my iPod is that it won't charge like for example ur battery is at 20% it would stay there it won't charge at all I don't know if it is my charger or its my iPod
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi,
Without knowing more details about your ipod (if you dropped it, spilled water on it, bent the charging port etc), these are my suggestions:
The first thing to try would be a different charger and a different outlet, to ensure that those are not the culprits.
Batteries do have a limited life span; after a certain number of charges (~2000) they will start to fail until they eventually can't hold a charge anymore. You could be due for a battery replacement. This guide, up through step 16, outlines how to do this.
iPod Touch 第五代 主板更换
You could also have an issue with the charging port, a replacement is outlined here, through step 27.
iPod Touch 5th Generation Rear Case Replacement
Good luck!
iPod Touch 5th Generation 主板图片
指南
iPod Touch 第五代 主板更换
难度:
困难
1 - 3 hours
iPod Touch 5th Generation Rear Case图片
指南
难度:
困难
这个答案有帮助吗?
得分 5
1条评论:
Great answer! You need some more rep!
完成的
添加一条评论
I think you should check your charger on another apple device to see if it charges that and if it doesn't its not your ipod its your charger
这个答案有帮助吗?
得分 0
1条评论:
This has already been resolved and accepted.
完成的
添加一条评论
添加你的答案
Zubair 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 187
