跳转到主内容
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
218 个问题 查看全部
Why does this phone keep restarting?
I can't understand why on other sites this phone is being praised. Ever since Ive had this phone all it does is shut down or restart. I could be typing something and out of the blue it will restart. It's annoying because it happens almost 6 times a day. I can't watch movies without it randomly restarting, I can't finish a text or go to my Twitter page without it shutting down or the bars dropping to 2 and making the internet slow down. Why is this happening? Is anyone else experiencing this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
11条评论
Short answer, take it back, theres obviously something wrong with it and if it has been happening since new then i doubt its fixable and will need to be replaced.
完成的
why does mine rebot itself all the time so i loose all my stuff
完成的
Just purchased my phone last month and started to reboot on its own. 3 times so far. No warning...just shut down and restarts. No messages afterwards as well. Was told that the phone was new.
完成的
I've only had mine a little over a month & now, I'm starting to have the same exact issue, except mine sometimes, won't even come back on at all!!!
完成的
My ZTE Zmax Pro is a replacement and it restarts itself a couple of times a day. It's annoying.
完成的
显示更多的6条评论
添加一条评论
1个答案
已选择的解决方案
This is starting to sound like a factory defect. Yes I love fixing stuff. However when it's like this, it's best to just bring it back. I haven't even looked and...ok I did look and even.. @jayeff confirms its a factory defect. Sounds like bad battery to me. Should be covered under a warranty
这个答案有帮助吗?
得分 2
2条评论:
my phone is a zte max pro and it wont stop restarting and we have taken it back and they said they cant do anything about the problem i was wondering if you can fix it for me or tell me how to because i have every important stuff to do on my phone for work and if i wont stop i might lose my job.
完成的
The ONLY answer or "solution" is an obvious one. There's no way to fix a defect other than to return the unit for a replacement. Especially if the manufacturer says they can't fix it. Good news is, all ZTE ZMax and ZMax Pro phones are not created equal. Meaning, they're not all defective. They're GREAT phones but as sure as it's man made, it has "breakdown potential". These phones are inexpensive on eBay and maybe, Amazon. Grab a replacement on me.
完成的
添加一条评论
添加你的答案
Dominiique 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 14,644
