跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
broken screen help with front camera
I bought a used 5c from a friend with a previously replaced screen that was cracked. When I opened it up I noticed where you plug the front camera into on the board had missing prongs and was damaged will the phone still work with a new screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Do I just not plug the front camera in will the rest still work?
完成的
Wanted to add it still charges and when I plug it into the computer iTunes responds to it Screen I have was cracked and damaged so cant see anything on it
完成的
I can't say for sure if the phone will still work with the damaged FPC connector for the front camera on the logic board, since you said pins are bent on logic board it may stop the phone from working if it is shorting against other pins.
完成的
添加一条评论
1个答案
最有帮助的答案
Without the front camera flex you won't be able to use the proximity sensor, ambient light sensors, in ear speaker or loudspeaker microphone so I wouldn't really consider it viable unless you only want to use it as an mp3 player.
这个答案有帮助吗?
得分 1
2条评论:
Hi I am wondering if that would affect the home button at all
完成的
The home button connects via the charging port assembly with two connection prongs so it won't affect it at all.
完成的
添加一条评论
添加你的答案
bill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 73
