跳转到主内容
Headphones released in 2011 for use with XBOX 360. They are identified by the model number X12.
26 个问题 查看全部
How can I splice my wires back together?
My cat chewed through my headset. I can see all wiring but not sure how to get them back together. It was chewed through above usb port and below the jack that plugs in to the controller.
Update (09/01/2016)
Picture of what the wires look like
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
As long as you know what wires connect you each other you will be fine. If you have access to a soldering iron, that would be your best bet - simply solder them back together, ensuring that you keep each different color completely separated from the others and then using electrical wire or heat shrink to cover each individual color.
What ever you do do though, it isn't going to look very neat anymore unfortunately.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Trey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 724
