跳转到主内容
A transforming "laplet" in the Lenovo Yoga line.
9 个问题 查看全部
Why does my screen have small flickers?
Hi guys. I recently got a lenovo yoga 14 and ever since the set up, my screen has these small, box shaped flickers. I installed the nvidia drivers and sort of mitigated the settings, but that had almost no effect. They pop up every once in a while, and I am concerned. Can I fix this? Thanks. Ps, the screen only flickers a little, it does not shut off.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
It might be your connection check your cords are plug in right, or you just might need to clean the connectors . You also can go on to youtube.com to watch videos and see if they can fix your problems. I hope this helps.
这个答案有帮助吗?
得分 0
1条评论:
thanks, ill try looking on youtube and cleaning my connectors. I hope it works
完成的
添加一条评论
It sounds almost as the problem I had. When I typed an address in Firefox and the suggestions were showing, they kind of got blurred out by black boxes.
I tried installing the intel graphics drivers from intel, but they did not recognize the hardware.
So I installed the intel vga drivers from lenovos site and after that the problem was gone.
This was for the yoga 510-14 isk, but it might help.
Cheers!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Droneking246 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 637
