keeps searching for network
my phone can't find a service it just says "searching" for network and it doesn't connect .. and even when a remove the sim card it doesn't says "No sim " installed it keeps saying "searching"
did you get it wet ??
or drop it??
just based off your brief description sounds like a bad sim tray or broken solder from sim tray to board
but i would always try a new sim card first as its the cheapest route and could always go bad
这个答案有帮助吗?
'''You try to press the Home button + power button until you see ' ' Apple ' '
Then insert the device into airplane mode for a few seconds and return back to normal
This should help'''
这个答案有帮助吗?
can not because even i don't put sim card into the iphone 5s also same problem
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 164
