跳转到主内容
Battery replaced, charging port is fine, but will not charge.
I purchased a Micro awhile ago and tried playing it a few days ago. I've a few of these so I have made basic repairs in the past. In this case I replaced the battery since it had been so long since using it last. It won't charge now. The battery was tested in other micros, so was the charger. The charging port looks fine. After taking it apart however I did notice the 2 little wires behind the white box where the battery plugs in looks corroded or possibly shorted so I'm guessing no current is coming thorough. Not sure how to fix this or if its a lost cause. Can anyone help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The fuse protecting the charge port may be dead - do you have a multi-meter? I haven't worked on the GB Micro before, but I have encountered a similar problem in the DS Lite. Using a multi-meter, do a continuity test on the fuses shown in the pictures shown in the thread here.
The continuity test simply checks to see if electricity will flow through the fuse. If it flows, you'll hear a loud beep to indicate it. If not, you'll need to replace that fuse.
这个答案有帮助吗?
得分 1
2条评论:
On a side note, is this the original Micro or the Anniversary edition?
完成的
I am working on a silver micro, though I did fix my 25th anniversary a few months ago. I'll go ahead an try out the multimeter. Thanks!
完成的
添加一条评论
添加你的答案
Hector 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 1,202
